2004 396MY Salon AC Replacement
- Timster13
- Vessel Info: 2004 Carver 396 Extended Salon (Floor Plan B)
Cummins 370s - Been thanked: 1 time
I was hoping someone could point me in the right direction.
I will be replacing the Salon AC unit in my 396MY as my old one gave up the ghost. I have found a suitable replacement from MarinAir but am having trouble determining how to get the old unit out and the new one in.
My salon layout is he extended salon with a dinette on the STBD side. The AC unit is located behind the entertainment center on the STBD side by the aft cabin stairs There is an access panel next to the stairs going down to the aft cabin but it is not big enough to extract the old unit.
I suspect that I may need to remove the entertainment center, but don't see how. It appears to be connected to a wrap around piece of countertop that runs behind the STBD couch. The countertop has a seam with a wood moulding that appears to be glued in place so speration could be a challenge. Also, the base of the entertainment center houses the central vac.
I have gone through the user manuals and the parts assembly documentation for the 396MY but have not been able to find any guidance.
Any thoughts?
Thanks,
Tim
- waybomb
- CYO Moderator
- Has thanked: 61 times
- Been thanked: 481 times
Re: 2004 396MY Salon AC Replacement
- Cooler
- Has thanked: 68 times
- Been thanked: 406 times
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Greg
- Timster13
Regards,
Tim
- Timster13
Tireless wrote:Source of the post In my 2006 Carver 44 CMY, which is the same boat basically. I can access the salon air unit via removable wooden panels in the stateroom closet, starboard side, beside the steps. They are a good size. Have a look and let me know.
Greg
Thanks Greg,
I dont see panels other than the cedar planks in the closet. Does your 2006 have a small access.panel between the closet and AC unit? Mine does and it grants access to the area with the AC, but it's definitely too small to fit the unit through. I will be investigating going through the closet even if I have to cut an access panel inside.
Regards,
Tim
- Tireless
Greg
- Been thanked: 601 times
You need to get in the cabinets and entertainment center on your back with a good flashlight.
I 'll bet you find a way to get to the unit.
- DanM
- Vessel Info: Carver 396
- Been thanked: 34 times
I have pulled those closet panels but I don't remember being able to access the AC system from there. There may be another panel that is behind the cedar that needs to come out.
Very curious as to what you come up with Tim as I have been wondering about that.
Carver 396
SugarSand Tango
- Timster13
Regards,
Tim
Users browsing this forum: Google Adsense [Bot] and 67 guests
