Aluminum gas tank 88’ 3807
- VicB
- Vessel Info: 1988 Carver 3807
- Has thanked: 41 times
- Been thanked: 11 times
- Has thanked: 603 times
- Been thanked: 1311 times
Re: Aluminum gas tank 88’ 3807
If it was my boat I would have done both tanks when the one went, but clearly that does not help you now.I sympathize with your position, it would be stressful not knowing when the other hammer will/may drop, especially gasoline. But a reminder, a lot a care would be required in safely removing the tank and it's contents.
Good luck with it , I am sure there will be many comments on this for you to consider.
- Been thanked: 1113 times
If you ever do get on board and smell a lot of fuel, be prepared to pump out the tank as soon as possible, and make arrangements to get to a shop, even if you have to go on one engine or get towed with blowers running, hatches open, etc.
Go out, enjoy the boat, and deal with it later if it happens at all, unless you find evidence that it should be done now.
Of course if you're worried and feel you should be proactive....
- VicB
