Dead House Battery
- jspin101
- Vessel Info: 2005 Carver 41 CMY w/ 2006 Volvo D6 370I-B's
- Has thanked: 8 times
- Been thanked: 2 times
Dead House Battery
I went to charge my batteries the other day and found the house battery wasn't holding a charge. I didn't have time to troubleshoot but want to go back and do some testing. Test all the batteries.
I was wondering if anyone has any advice on a Battery Tester / Load Tester, multi tester units. I've been reading about all the different types. Articles mention the load testers are best used around 70 degrees ( it's about 50 to 60 degrees colder around here so that won't work), some mentioned that you can test the load with a capacity tester, some say resistance tester, etc...
I welcome any advice.
Thanks,
Re: Dead House Battery
It does fine for someone not using it all day everyday.
- Been thanked: 654 times
I keep one of these on the boat though, it works just fine for the occasional check: https://www.amazon.ca/gp/product/B08F9SBXN9/ref=ppx_yo_dt_b_asin_title_o02_s01?ie=UTF8&psc=1
I'm sure it's also on .com.
The electronic tester types are great for reading several batteries one after the other. On a bad reading though, I usually follow up with a load test using a toaster test because I like to see what happens after a load is applied. Having said that, you can chart the results of a load with the unit on Amazon by turning on a high load in the vessel. That's good to know in certain cases. The problem with using just a toaster for testing is that you shouldn't be using it to test several batteries in a short time because to get an accurate reading, you're suppose to let the element cool down completely before testing the next battery. That's not practical when you're on the clock and have several batteries to test.
https://www.amazon.ca/FOXWELL-Automotive-100-2000-Cranking-Charging/dp/B07F1G1X48/ref=sr_1_25?dchild=1&keywords=battery+load+tester&qid=1612950917&sr=8-25
One does not need to spend that kind of money to get something similar however at this price it does not do alternator/charging tests.
https://www.amazon.ca/Foxwell-Battery-100-1100-Cranking-Directly/dp/B01M02Y9AL/ref=sr_1_17?dchild=1&keywords=battery+load+tester&qid=1612951102&sr=8-17
,, I mean old fashioned. I've got several digitaL meters too but for a simple check its quick and inexpensiveCrusader xli
Bothered me for months. Every birthday thereafter never a thought, go figure!
58 is an excellent vintage, mine in fact.
- Been thanked: 1111 times
Do you know why it went dead? One time I left my fully charged and good batteries but forgot to disconnect the auto bilge pump... the kind that runs every couple minutes for just a couple seconds. That was enough to kill the battery over a couple month, even enough to allow it to freeze (we had a very cold winter that year). The battery was only a couple years old but it was toast when I tried to revive it the following spring. It did take a charge but really didn't have much capacity anymore.
