Solar Panels
Has thanked: 432 times
Been thanked: 1587 times
Re: Solar Panels
Postby Viper » February 10th, 2021, 8:08 pm
Tireless wrote:Source of the post
Midnightsun wrote:Source of the post One thing to keep in mind, the hotter a panel gets the less it performs. A flexible panel directly on a roof cannot breath therefor suffers much more than if it were elevated to allow air flow underneath. They do need to dissipate heat to be most effective not to mention they will last a lot longer if not overheated.
This is an excellent point raised by Midnight sun and I should have mentioned it.
This is why I used the elevator bolts. My panels do not rest on the fibreglass, however, I will be putting a spacer in the centre, on the under side of my panels to ensure more air flow.
Greg
Ya air flow for cooling is definitely important but you also don't want that sitting directly on the fiberglass because if any sweating goes on or the space under the panels retains rain water you will likely end up with blistering of your gelcoat, pretty common under some things like bow cushions.
Re: Solar Panels
Postby Viper » February 10th, 2021, 8:10 pm
Midnightsun wrote:Source of the post Panel canvas install in the Thousand Islands region is very popular. Most of them use small sewn in flaps with velcro to secure the panels in place. This will give you a good idea of whats out there. https://www.google.com/search?q=canvas+ ... =945&dpr=2
Ya the Velcro installs is what I'm most used to seeing.
Re: Solar Panels
Postby Viper » February 10th, 2021, 8:37 pm
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 441 times
Been thanked: 190 times
Re: Solar Panels
Postby pepmyster » February 11th, 2021, 5:59 am
Using flex panels. We are using earth magnets to hold them onto the canvas. No holes, no seams. These magnets are great to hold them even in a major storm. Then, pop them off in the fall, then put away the panels. As you can see, there are many different ways to do this. Just keep them clean and verify them once in a while. We never cover them. Love the freedom this has given us.
tonyiiiafl
Has thanked: 588 times
Been thanked: 175 times
Re: Solar Panels
Postby tonyiiiafl » February 11th, 2021, 10:15 am
Thanks, I am leaning towards the rigid panels with elevator bolt installation. I can get 2 panels and have an output of 390 watts, versus 2 panels of flexible at 200 watts. I am hoping to have room for 3 panels, which seems plausible, and 580 total watts. The controller will handle it the rep said. I would have some room left to get on. The hard top if needed. Mounting them an inch or so above the hardtop will allow cooling. Also, it will shield the top from the suns rays and slow down the chalking of the fiberglass that I have to compound out every year. More soon!
tonyiiiafl
Re: Solar Panels
Postby tonyiiiafl » February 19th, 2021, 4:39 pm
Tireless wrote:Source of the post A friend of mine used the rigid panels on his aft hardtop. He used the elevator bolts to fasten them to the fibre glass under the brackets.
I had to go with the soft panels as I didn’t want the weight associated with the rigid panels on this top. My hardtop over the fly bridge is not load barring. The soft panels are excellent and work very well.
I also did not want to drill holes in the hardtop. The wires on top are not that attractive, but you can’t see them normally, unless you are on the top side of a lock.
I do not cover them and they remain on my hardtop all winter under my cover. If they get dirty from birds or other things, they wash off.
This is how I handled the installation and it may not fill the needs of others.
Greg
Greg, what brand did you use? I am not too concerned about 80 or so pounds on the aft hardtop, but am looking at either Renogy 400W/40Amp control;let or Rich Solar. Opinion? Rigid is a definite so I can allow air flow under them
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 185 times
Re: Solar Panels
Postby Tireless » February 21st, 2021, 11:09 pm
My panels are made by Sunpower. You can check out the panels and controller at Marine Solar Innovations here in Canada. This who I purchased mine through. The owner is very good to deal with.
My friend installed the rigid panels (2) on his aft deck hard top as he also had no weight restrictions. They were not 80 Lbs. A lot less than that, I helped him install and the elevator bolts worked to hold the brackets very well.
Greg
tonyiiiafl
Re: Solar Panels
Postby tonyiiiafl » February 24th, 2021, 6:58 pm
I pulled the trigger today. I got this set for the aft hardtop of my 390CPMY
https://www.ebay.com/itm/Renogy-400W-Wa ... 2749.l2649
And these mounts:
https://www.ebay.com/itm/7PCS-Solar-Pan ... 2749.l2649
And these parallel Cable set:
https://www.ebay.com/itm/Renogy-One-Pai ... 2749.l2649
Total weight is 56LBS, so that should not be a problem as my former fat self at 275 has been on that roof plenty of times. I am happy with the mounts as there will be plenty of surface area to stick using butyl. Arriving March 4, I will install once boat is launched. In addition to the fuse, I am planning on putting a battery disconnect switch between the line from the panels to the controller so I can shut it off.
Wish me luck! I think I overthought the entire process!
Vessel Info: 2022 Stingray 182 SC
Been thanked: 464 times
Re: Solar Panels
Postby RGrew176 » February 25th, 2021, 8:26 am
Keep us updated as you progress. Good luck.
Liechtenstein
chpsk8
Has thanked: 27 times
Been thanked: 70 times
Re: Solar Panels
Postby chpsk8 » February 25th, 2021, 4:03 pm
What's your plan for routing the wires to the battery bank? I have yet to find a clean way to get them to the arch so I can get to the bilge. My hardtop isn't hollow, it has some wood in there. Found that out the hard way with another project I was working on.
Post up some pics of the install when you do it. I think a lot of people would be curious of the parts required and the install methods. We have some good real estate on the roof, might as well make use of it, and power is always appreciated.
