Fuel pump for Generator
jsurfwhite
Vessel Info: 2000 Carver 356 Aft Deck
Has thanked: 12 times
Been thanked: 4 times
Postby jsurfwhite » February 12th, 2021, 5:08 pm
I have a Kohler 7.3e generator. The fuel pump is badly corroded and needs to be replaced. My manual does not list the part number. My search so far has found Facet 278490. Can someone confirm that number? I have had a few misses on part number cross references that resulted in repair delays and returned parts. Thanks
Re: Fuel pump for Generator
Postby tomschauer » February 12th, 2021, 9:58 pm
Italy
KeithS
Vessel Info: 2005 38SS
Been thanked: 23 times
Postby KeithS » February 13th, 2021, 10:38 am
278490 is the correct Kohler part number for the pump. It is made by Faucet but be careful to get the correct pump if you get it aftermarket. Faucet makes several versions of that pump that are identical on the outside but have different ratings. Putting in a pump that has 7 psi instead of the 2 psi can cause the carb to run rich and flood.
jsurfwhite
Postby jsurfwhite » February 13th, 2021, 7:07 pm
Any tips on the installation? How do I prevent fuel from siphoning from the fuel tank? Thanks.
Postby tomschauer » February 13th, 2021, 7:56 pm
You have an anti siphon valve at the tank, you should only lose the fuel in the line.
I would also order the small metal cartridge fuel filter and replace at the same time.
Make sure you connect the power plug correctly. If you reverse the polarity, your pump will run backwards and not pump enough fuel to keep the genny running. Don't ask how i know this!
Users browsing this forum: No registered users and 46 guests
