Installation of 400 Watt solar kit (4 panels) 390CPMY
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Re: Installation of 400 Watt solar kit (4 panels) 390CPMY
I have 4 panels. They are separated 2 and 2 to ensure that the shadows don’t interfere with the charging.
I put my controller in my salon to shorten the run from the panels to the controller. I was told to keep it under 20 feet for the gauge of wire that came with the set up. I was then able to keep the wire going from the controller to the batteries under 14’.
Greg
- tonyiiiafl
If I placed my controller in the Salon, I would have approx a 15’ run from panels to controller and 5’ to the 2 6V golf cart batteries wired in series to make 12V. Next year I would like to add another 2 6V batteries bank to supplement my house bank. Looking forward to your reply as to how you have the panels connected.
- tonyiiiafl
- Tireless
I don’t turn the panels off during the season when there are other methods of charging taking place. The controller accounts for this and there is no issues. This is great if there is a power issue at the dock and your batteries will still be charged. The panels are always powered up any way.
Your distances sound like they are within spec.
Greg
- tonyiiiafl
- tonyiiiafl
- Tireless
As for the product to use to hold down your brackets, I used 3M 4200 as opposed to 5200. 5200 is stronger, but if you ever want to remove them for what ever reason it would be more difficult. I was advised that 3M 4200 is sufficient for this application, however you should go with what makes you comfortable.
Greg
