Stern Thrusters
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Stern Thrusters
My boat currently has a Volvo Penta QL Bow Thruster and I am still researching stern thrusters. I have a large rock shelf on the port side of my boat slip that gives me a bit of stress on a windy day, as the wind has a tendency to push the stern over. I have been fine so far, but I just think a stern thruster in addition to my bow thruster would be really handy. Cost has been a big factor in this decision, but the search still goes on.
I have been looking at two types so far.
The Side Power stern thruster attaches to the transom above the water line and is wireless to the helm switches. It can also thruster to wireless that will work with their dual joy sticks as well as a wireless remote. I can install this unit myself and they suggest it will take 6-8 hours.
The other one is more common and made by Side Power. This unit has the motor mounted inside the boat and a tunnel on the outside below the water line. This requires a number of holes (10) to drilled through the transom under the water line. The installation of this unit would be a bit more complicated and may require the assistance of a professional. The struggle would be ensuring there is sufficient room on the inside of the transom for the motor. This unit also has a dual joystick that will operate the QL.
Both units are approximately the same dollar value, however, if you add professional installation you are double the cost, which makes me wonder if it is worth it in the end.
I posted this to see if anyone has any experience with either of the products and offer an opinion to assist me in making the best decision.
Thanks in advance.
Greg
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Stern Thrusters
As to the install, he had them/Pat do it from what I remember. They may be looking for business as we get frequent e mails from them offering deals of all sorts.
Re: Stern Thrusters
Remote Control Upgrade. https://shop.sideshift.com/collections/ ... -thrusters
Thruster. https://shop.sideshift.com/collections/ ... thruster-2
Re: Stern Thrusters
Here are examples:
https://www.yachtthruster.com/
https://side-power.com/produkt/20485/ex70c-external-stern-thruster-24v/
What ever you do, don't put a pod on the bottom of the hull.
Re: Stern Thrusters
Re: Stern Thrusters
I've seen a couple of Sideshift motors fail recently from leaks even after their improved seals.
I had a Sideshift unit on a previous boat and sure enough the seals went after about 8 years. I now tell everyone to replace the seals every 5 years as preventative maintenance if you do not want to dish out the cost of a new motor which by the way is almost the cost of the entire kit.
- Tireless
Re: Stern Thrusters
So no matter what I install I will require require a special bracket that conforms to the shape of the transom.
All of the concerns raised in relation to the exterior unit are excellent thoughts, and to be honest I did not consider. Because I must go with an under water mount anyway, then the SidePower unit, with the mechanical workings inside, makes sense. Time to get in there and take some measurements to see if there is room for that on the inside of the transom.
I will have a look at recommendations by Viper. Not in a rush here and will continue to look at all options. The irregular shaped transom is going to be an issue. Need someone who has a Carver 444 CMY, with a stern thruster to jump in and tell me how they did it and what they used. Pictures would be good if you’re still on the hard.
Greg
Greg
- Tireless
Re: Stern Thrusters
Need to figure out how to mount a stern thruster here. This may limit my options. Also wonder how something mounted on/under the cockpit/transom would impact performance.
Thoughts
Greg
- JohnS
- Vessel Info: 2003 350 Mariner
- Has thanked: 39 times
- Been thanked: 16 times
Re: Stern Thrusters
