1750 RPMS
Michaemac
Vessel Info: 2005 Carver 56 Pilothouse
1750 RPMS
Postby Michaemac » April 25th, 2021, 6:58 pm
Anyone have a solution as to why my boat won’t rev higher than 1750 rpms? I have 2005 56 Pilot house.
Has thanked: 78 times
Been thanked: 1093 times
Re: 1750 RPMS
Postby km1125 » April 25th, 2021, 7:20 pm
I don't know that system at all, but it seems like Error 55 on a CruiseCommand comes back to a battery issue.
Is this just one engine or both?
Michaemac
Re: 1750 RPMS
Postby Michaemac » April 25th, 2021, 7:42 pm
It’s on both engines. Not sure if that’s the issue. I will power them off and back on and see if that’s the issue. When I run her at 1750 it shows 100% load on the engines?
Has thanked: 469 times
Been thanked: 1765 times
Re: 1750 RPMS
Postby Viper » April 25th, 2021, 8:32 pm
Did you check the basics first; clean air filters, clean fuel filter assemblies, new fuel filters? Do they smoke a lot? Does the boat get used a lot, how old is the fuel?
It would help to know what engine package we're talking about here.
Been thanked: 284 times
Re: 1750 RPMS
Postby buster53 » April 25th, 2021, 10:17 pm
When was the last time the bottom and running gear was cleaned?
Michaemac
Re: 1750 RPMS
Postby Michaemac » April 25th, 2021, 10:44 pm
All the maintenance has been done on the. Cummings engines. J believe they’re 660’s. It just happened for the first time last week.
I’m thinking of restring the cruise commander. I also have trolling valves installed in vancouver for fishing. I got some wired going on.
Re: 1750 RPMS
Postby km1125 » April 25th, 2021, 11:26 pm
Is it possible it's in trolling mode? Again, don't know that system but just doing some quick reading it seems like you can toggle it into a "trolling mode" which restricts the engines so they only will go to part throttle.
Re: 1750 RPMS
Postby Viper » April 26th, 2021, 10:15 am
Some applications also have a switchable low rpm setting for docking, etc.
