1996 370 Voyager Twin 454 Crusaders
- Hold'n On II
- Vessel Info: New to us 1996 370 Voyager
- Been thanked: 11 times
I was pulling plugs and marking wires at both the cap and plugs on my starboard engine and noticed the firing order on the manifold is the same as my port engine 1,8,4,3,6,5,7,2.... Had to do a double take.... various other clues have me thinking the starboard engine may be a re-power, or at least pulled for a re-build at some point (Pulleys, Pumps, Pan, Block, Manifolds Valve Covers have been painted over with darker blue, the floor between the dinette seats appears to have been dissembled at some point). I would like to contact Carver with serial numbers but cant seem to find them. Where do I look?
TIA
Ken
Re: 1996 370 Voyager Twin 454 Crusaders
- Has thanked: 603 times
- Been thanked: 1311 times
Hold'n On II wrote:Source of the post I would like to contact Carver with serial numbers but cant seem to find them. Where do I look?
Have a look at the top of the bellhousing, maybe in that area.
There is no "cut off" date, as many boat manufacturers had stock engines of various size / hp that they used before going to all standard rotation.
- Cabin Boy
- Vessel Info: 1994 Carver 370 Voyager .
Twin 454XL inboards with 1609 hrs.
Has the up galley and dinette , lower salon at entry . Two forward Staterooms , forward centerline Queen , Port with bunks ,
Full Flybridge enclosure .
Moored in La Conner , Wa. - Location: La Conner , Washington
- Been thanked: 8 times
Both engines are standard rotation and the reverse rotation is through the transmission .
If the sparkplug wires on the distributor caps are wired the same , then your reverse rotation is through your transmission.
You can also look at the shift cable linkage on the transmissions . You'll notice one of the transmissions will have the cables reversed .
