Gas tank leak
- Matt1989Carver3807
- Has thanked: 13 times
- Been thanked: 3 times
Gas tank leak
After all considerations my current thought would be to totally empty tank of gas and fumes first. Then have the tank people remove the tank and have a custom made half size tank (70 or so gal) that will fit the space and can be used for gas needs and ballasting needs. Ballasting will not be perfect I realize due to smaller size. Additionally, the exhaust and manifold of the port engine can be moved and replaced without interfering with the engine alignment and minimize the cost.
Would love to hear some thoughts/suggestions.
Re: Gas tank leak
- Has thanked: 603 times
- Been thanked: 1311 times
Re: Gas tank leak
Matt1989Carver3807 wrote:Source of the post Then plan to run engines with blower going until port tank runs "empty". We have a tank manufacturer who has visited the boat and consulted.
Matt1989Carver3807 wrote:Source of the post Would love to hear some thoughts/suggestions.
Considering you have a known leak, my advice is to have it pumped dry now and repaired, don't take any chances, those leaks may start out as a seep or drip and change without notice. Never the less the fumes from even a tiny leak/seep or damp spot are explosive. Be very careful here.
- Been thanked: 1113 times
Re: Gas tank leak
Can you plumb or switch the engines so they both just run off the starboard tank? Then just pump whatever you have in the port tank over to the starboard side and use it up. Refill the port tank with water so if/when it leaks into the bilge it's not a big deal and it also provides ballast to counter the gas weight on the other side. Continuing to use a boat with a known gas leak would be very scary in my opinion.
- boatdave
- Vessel Info: Currently looking for 396 Carver
- Has thanked: 6 times
Re: Gas tank leak
Re: Gas tank leak
Viper wrote:Source of the post That's interesting. I'll take a look a closer look at mine but going strictly by memory, I don't see how you can remove that tank without removing the engine unless they're planning to chop up the tank in place. Don't think I'd reduce the size of the tank for a few reasons but I get that the wallet dictates.
I do think removing the tank by by chopping it up is a part of the plan. I understand a pneumatic tool is used to prevent sparking.
Re: Gas tank leak
bud37 wrote:Source of the postMatt1989Carver3807 wrote:Source of the post Then plan to run engines with blower going until port tank runs "empty". We have a tank manufacturer who has visited the boat and consulted.Matt1989Carver3807 wrote:Source of the post Would love to hear some thoughts/suggestions.
Agree with your concern and advice. In the overall considerations I do not trust the thought that our 32 year old tank can be repaired satisfactorily due to the fact that the leak has not been located. Would prefer I think to have a new custom made tank in place.
If your concern is about running the boat engines with the leak being unrepaired, I share that concern. All gas odor would have to be gone.
Re: Gas tank leak
Matt1989Carver3807 wrote:Source of the post If your concern is about running the boat engines with the leak being unrepaired, I share that concern. All gas odor would have to be gone.
It is exactly that, by repair I meant in your case with an old tank......replace. Even with the odour gone and our noses can detect extremely small amounts, that doesn't change the fact that it could open up at any time with temp changes, vibration etc. Unfortunately this is one of those things that comes along with an older boat ( and some newer ones) that must be dealt with safely......good luck and be safe.
Re: Gas tank leak
Re: Gas tank leak
