Hello
- Bilgewater
- Vessel Info: 78 Carver 3396 Mariner
- Has thanked: 2 times
Hello
- Has thanked: 468 times
- Been thanked: 1765 times
Re: Hello
While it may seem that they're leaking from behind the frames, a lot of times they leak because the channels can't drain. This is usually the result of an accumulation of crud that once cleaned out usually cures the problem, so check that first before committing to removing the entire assembly to re-bed it. If the problem is drainage, you'll have the same issue after re-bedding. Having said that, re-bedding may be due as well for that vintage.
- Been thanked: 646 times
Re: Hello
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
Re: Hello
2022 Stingray 182 SC
- waybomb
- CYO Moderator
- Has thanked: 64 times
- Been thanked: 481 times
Re: Hello
