3807 Fresh Water Tank Loosing Water
- Raylap819
- Vessel Info: 1988 Carver 3807; twin GM 454s
- Has thanked: 26 times
- Been thanked: 654 times
Re: 3807 Fresh Water Tank Loosing Water
- Been thanked: 1113 times
Lots of possibilities for sources of leaks, anywhere from the tanks, lines, fittings, faucets, strainer, pump, ice maker, bar faucet, etc. Don't forget the hot water heater, for that vintage, its tank may already be leaking. Air in the system is usually an indication that something is loose or cracked before/at the pump. As mentioned, if the pump cycles periodically without running a faucet, you likely have a leak after the pump or the pump's check valve is leaking and it's draining back to the tank.
If you fill the tanks at the end of the weekend, turn the water pressure off, and return Friday to find they're empty and there's water in the bilge, chances are pretty good you have a leaking tank/s or lines, fittings, or strainer leading to the pump. If the tanks are still full when you return, you have a leak on the pressure. For that, turn your pump on or dockside water and then it's a matter of checking all areas bow to stern where there may be plumbing hardware, especially fittings and fixtures.
Good luck and let us know what you find.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Some years ago, I had a 3807 and my water pump went bad and needed to be replaced. I spent hours looking at that pump, running it over and over in my mind as to how to replace it. I was stumped. Then one day the light bulb turned on..
Don’t take the pump off the mount frame (basically impossible). Remove the mount frame from the boat with the pump attached to it. After it’s out, replace the pump and remount the frame back to the boat. Once I figured that out, it wasn’t that difficult a job to replace the pump.
Replacing the pump in a 3807 was way easier than my 356. That was a PITA.
- Raylap819
- Raylap819
- Raylap819
- buster53
The leak could be anywhere. Last time I had a leak in my system, I found it right near my water heater and it was a pinpoint leak, not easy to see.
The 3807 has 2 showers, one water heater and 3 lavortories…meaning, there’s a lot of water piping in the bilge and hidden in walls and behind bulkheads. Tracking down a pinpoint leak will not be easy.
