355 aft to bridge side clear panel
- tgmkwill
- Vessel Info: 1997 355 Carver Aft
- Has thanked: 1 time
- Been thanked: 3 times
I want to clean out a few years of crud in the corners and eventually repaint the base of the radar arch that is starting to peel.
It looks like after the screws all come out of the panel it is matter of lifting and tilting it in a specific sequence to get it out of the tracks.. my biggest concern it ends up being something that comes out but is a pain to get back in.
Any advice from someone that had take them out. ?
Thanks.
- chpsk8
- Has thanked: 27 times
- Been thanked: 76 times
Re: 355 aft to bridge side clear panel
- Been thanked: 601 times
Snaps out in under five minutes.
- tgmkwill
- RussL
- Vessel Info: 2000 396 Motor Yacht
- Has thanked: 18 times
- Been thanked: 11 times
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 23 times
- RussL
I think if you take the screws out it will simple slip down and you can grab the bottom. If not... I am not sure.. most likely you will need to buy a windshield removal tool to slide in and run around it to cut the silicone. I would not advice standing on top of the hard top to work from the outside. If you take yours out before I do, please let me know how it goes!
