410 Sport Sedan 8.1 Horizon performance question
- Ruger_Fan
- Has thanked: 3 times
Loving the boat but don't hate money so if I'm wasting a bunch I'd love to sort that out early on.
- Has thanked: 78 times
- Been thanked: 1093 times
Re: 410 Sport Sedan 8.1 Horizon performance question
Also curious that the spark advance is only showing at 1 degree. At 4000 and a heavy load you should have closer to 25 degrees total advance. I wonder that what 1 degree is indicating?
- Has thanked: 468 times
- Been thanked: 1765 times
Can't help you with the fuel burn, speed etc., hopefully a member with the same application will chime in with some numbers for you to compare with.
- Has thanked: 598 times
- Been thanked: 1281 times
What was the speed at that rpm/data point ?
That is a fair bit of HP you have and that means more fuel at higher rpms.
- Ruger_Fan
bud37 wrote:Source of the post To be honest, your data doesn't seem far off to me....I don't think your boat will get much better at that rpm. How is the bottom and running gear ...if they are fouled it will slow you down and use more fuel so keep it clean to maximize.
I was pulling right at 20mph at 4000rpm's burning approx 50 gph. fresh bottom paint and gear is all "clear" bottom is pretty smooth for a 20 year old boat with ablative paint no big areas chipped off or large amounts of "catches".
- Ruger_Fan
km1125 wrote:Source of the post Not specifically addressing your question, but a couple things jump out at me on those printouts. Oil temperature at 32F?? Must just be a default value and it doesn't actually measure temperature. Air intake temps seem pretty high for a high RPM. Probably normal for a hot engine compartment and low speeds but I'd think at 4,000 RPM you'd be sucking in a whole lot of fresh air from the outside and that temp would be closer to the ambient outdoor air temp (maybe plus a couple degrees).
Ya that motor must not have an oil temp sender feeding into the computer so the FOX unit just shows a canned value.
- Ruger_Fan
I've got a mechanic coming to look at it with me tomorrow as i ended up finding "burn through" on one of my exhaust hoses (Starboard). I'm guessing impellers need replacement as i bought the boat recently and have found zero maint was being done by previous owners. It never got hot but i suspect not enough water was flowing to cool the exhaust.
