Need help! I’m stuck and boat overheating can’t figure out why
- Iwantacarver
Keeps overheating wheneve the boat is sitting ag the dock only
When we drive it it doesn’t overheat
Any ideas???
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Need help! I’m stuck and boat overheating can’t figure out why
- Iwantacarver
- Has thanked: 603 times
- Been thanked: 1311 times
Do the engines have antifreeze in them or just raw water from the lake ?
Have you checked your impellers?
Did this just start for both engines ?
So to be clear....when the boat is not moving both engines will get hot no matter what rpm they are at?
This will help to sort this out.
- Iwantacarver
It happens at any rpm as long as it’s sitting at the dock or going less than 5MPh
- Dustin07
- Vessel Info: 1988 Voyager 2827
- Has thanked: 15 times
How hot is it getting? what are you doing when you see it overheating to get it back down? where we live, I have to idle out at about 5 knots for nearly 20 minutes just to get out of the harbor so I'd be in serious trouble if I was over heating at slow speeds.
Shoot the elbows with a IR gun to get the temp on them as well see if it matches the gauge. have you felt them to see if they are warm to the touch when the gauge says they are?
for 2 years (on 2 different boats) I have fought cooling issues (although opposite direction, never overheated at idle) so I feel for you. I have done a lot of trouble shooting on this issue over the last 2 years.
- Been thanked: 1113 times
I also wonder what the condition and age of the impellers are.
Do you have strainers? If so, check to make sure you're not sucking air in where the cap is. When you're cruising, water is being pushed up into the raw water pump due to the scoops, but when you're stationary the raw water pump has to suck the water up and if there are any air leaks it will suck in air too, reducing the amount of water it's able to pull in.
- Iwantacarver
Gas engines 320HP
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
It sounds like your engines are close cooled. I would like to know what the water volume is coming out of the exhaust to ensure you have enough going though the system or is there a circulation issue.
In addition to the things mentioned, like impellers, strainers and whether there is a blockage at the intake, what is your coolent levels in your reservoir. Could you be low in coolent (anti freeze).
Greg
- Iwantacarver
Users browsing this forum: Google [Bot] and 30 guests
