AC size
mitchellp
Vessel Info: Carver 1989 38 Aft
AC size
Postby mitchellp » July 26th, 2021, 4:03 am
I need to replace my salon ac unit on a 1989 Carver 38 aft. There is no information on the unit itself.
What size of unit do I need? 12,000 or 16,000 btu
thank you
Mitch
Been thanked: 285 times
Re: AC size
Postby buster53 » July 26th, 2021, 8:28 am
Are you on the Great Lakes or Florida coast? I assume you have 3 units on that boat and if so, I think the salon unit is 12k.
Re: AC size
Postby g36 » July 26th, 2021, 8:34 am
My 405 aft cabin has 16000 in salon
Re: AC size
Postby buster53 » July 26th, 2021, 10:29 am
g36 wrote:Source of the post My 405 aft cabin has 16000 in salon
OP didn’t say, but sounds like he has a 3807. I used to have a 3807 and if I recall, the salon was 12k.
Re: AC size
Postby g36 » July 26th, 2021, 11:20 am
I think their cu ft interior spaces of the 2 boats is pretty similar (just googling)but I do know with all the windows there's a lot of thermal transfer on both which ever he has ... I know I would not want any smaller, maybe even larger down here in Tennessee . :-D
Re: AC size
Postby Midnightsun » July 26th, 2021, 11:29 am
For what it's worth, mine came with a 16,000 btu for the salon and there is an 11,000 in the forward cabin that also partially supplies the salon. Point is the salon needs quite a bit to keep up. That being said I would definitely go with a 16,000 btu.
Re: AC size
Postby buster53 » July 26th, 2021, 1:23 pm
You have to be careful with sizing and electric draw. When we had all 3 AC units running on our 3807, we were pulling 29 amps. If we had replaced just one of those units with one another size larger, we would have exceeded the 30 amp limit, meaning we would only be able to run 2 units, not all 3.
Re: AC size
Postby g36 » July 26th, 2021, 7:04 pm
I would have thought a 3807 would have had 50 amp 120 service x2 like my 405 does instead of only 30 amp. Newer units would probably more energy efficient which will help too.
Re: AC size
Postby Midnightsun » July 26th, 2021, 8:22 pm
g36 wrote:Source of the post I would have thought a 3807 would have had 50 amp 120 service x2 like my 405 does instead of only 30 amp. Newer units would probably more energy efficient which will help too.
Or at the least dual 30's. Usually as soon as AC is added as an option they kick in an additional 30a inlet and in the case of multiple AC units dual 50a 110 or single 50a 220 is the norm.
Re: AC size
Postby buster53 » July 26th, 2021, 9:35 pm
g36 wrote:I would have thought a 3807 would have had 50 amp 120 service x2 like my 405 does instead of only 30 amp. Newer units would probably more energy efficient which will help too.
Yes, my 3807 did come from the factory with dual 50 amp, 120 volt service, however, when was the last time you saw a marina that offered 120-50 amp? I never have. Previous owner had special shore power cords made up…male 120-30 amp with female 120-50 amp. That way, the boat could be plugged in at any marina as all offer 120-30.
One cord powered all 3 AC units, other cord powered everything else.
