Source for 19 c36 AC strainer basket please
pmarko55
Vessel Info: 2019 Carver C36 Flybridge
Has thanked: 6 times
Postby pmarko55 » July 28th, 2021, 3:57 pm
Hi - Anyone know the model # for a replacement Aircon strainer basket for 19 C36 - and a source, maybe link, to buy online. Thanks for your help!
Re: Source for 19 c36 AC strainer basket please
Postby Viper » July 28th, 2021, 10:33 pm
It would help if you posted the brand of the strainer or a picture. Do you know if it's a Perko or Groco?
Been thanked: 285 times
Postby buster53 » July 29th, 2021, 8:34 am
Ok, IF you have a Perko, I can probably help you with part numbers or you can call Perko customer service at 305-621-7525. They are very helpful but you still have to buy parts from a retailer, not Perko.
Can you measure the existing basket? That will tell you which model strainer you have.
I’m guessing you will need either 049300599D or 049300799D
pmarko55
Postby pmarko55 » July 30th, 2021, 11:29 am
Thank you both SO much for responding. It is so kind of you. The AC make is WEBASTO but the manual doesn’t say what model and doesn’t specify what make or size basket to use. When I measure it, it seems be about 1.5 or a bit bigger in diameter, and the length of the basket itself seems to be about 4 3/4 but the handle had broken off and the well for the basket seems to be longer ie it could accommodate another 1/2 or full inch.
Postby tomschauer » July 30th, 2021, 11:47 am
The A/C unit manufacturer didn't make or supply the strainer. There should be a name on the strainer.
pmarko55
Postby pmarko55 » July 30th, 2021, 4:37 pm
Will check again - thanks!
Postby buster53 » July 30th, 2021, 10:42 pm
The smallest basket that Perko makes is 1-13/16” in diameter. The part #049300599D has a full length, with handle of 6-1/4. The only smaller basket they make is 4-3/8” high.
Again, I’m assuming you have Perko. FYI, I got my parts from Fisheries Supply.
Postby buster53 » July 30th, 2021, 11:28 pm
If you have a Perko, the top is held down by 2 bolts with wing nuts. A Groco has a screw cap. Perko has parts diagram on their website, Groco probably does as well.
Postby buster53 » August 14th, 2021, 4:31 pm
What did you find?
