Discoloration on TAMD 75
Tbw5959
Vessel Info: 2004 466 M/V Salt and Light
Volvo TAMD75's & Kohler 20kW generator
Has thanked: 39 times
Been thanked: 4 times
Postby Tbw5959 » August 16th, 2021, 12:32 pm
hello All, quick question, going to survey on a 2004 466 in a couple weeks, but saw this 'discolored area' / overheated? area on 1 of the engines, and wondering what that might be?
Maybe others have seen this same thing and figured it out or have a theory about it?
Please see pic attached, any ideas/recos? Thanks much
Carpediem
Vessel Info: In process of buying 2000 506 with Volvo TAMD 74s
Been thanked: 25 times
Re: Discoloration on TAMD 75
Postby Carpediem » August 17th, 2021, 1:06 am
My engines have the same issue, The paint is just burned off so the cast iron manifold is rusting. At some point you will want to wire brush the area and repaint. Keep and eye on it for signs of an exhaust leak, you will see soot if there is a leak. I don't think it is a sign of any thing serious.
Try to only boat where ducks don't walk
Postby Viper » August 17th, 2021, 6:52 am
I agree, it's exhaust, it gets hot. My biggest concern would be the mounting studs. They're looking like they might be getting to a point where they'll get so rusty they'll break if you ever have to get the nuts off, so you may want to be proactive and have the studs replaced. Other than that, brush the area and coat with high heat paint.
Hope the survey goes well. Keep us posted.
Tbw5959
Postby Tbw5959 » October 4th, 2021, 6:10 pm
Yep, surveyor confirmed that's exactly what has happened / is happening -- uncooled area, gets very hot (FLIR showed ~400 deg F), paint bubbles off, then metal rusts.... Volvo Tech re-confirmed and said 'they all do that'..
Carpediem
Postby Carpediem » October 9th, 2021, 11:35 am
This is a winter project for me on my 506, I am going to remove the turbos and induction pipes and recondition them, there are a few layers of burned discolored and flaking paint on the compressor section that really bothers me. The whole engine room actually is getting totally refreshed. The aluminum plates that the engines are mounted to are all blistered with corrosion under the black paint, going to be a miserable and tedious job but it will be worth it in the end.
Users browsing this forum: No registered users and 7 guests
