Fresh Water Level Gauge
- SeattleMatt
- Vessel Info: 1995 Carver 320 Voyager
Twin Crusader 350XLHT - Location: Seattle
- Has thanked: 12 times
Anyone ever replace one of these? How do you get it out? I tried removing the screws and they just spin.
I suspect they are all glued down and stripped out, is this common?
Any suggested replacement systems?
Thanks.
- Been thanked: 654 times
Re: Fresh Water Level Gauge
They come with a gasket but do you also see any sign that there's caulking between the unit and the tank? It may just need to be carefully pried up at each screw location while you undo each screw. I can't see the tank having embedded nuts so they may just be screws going into a thickened section of the tank and the holes for each are stripped so prying may help but go easy, or try grabbing each screw with a pair of pliers and pull while you turn.
Carefully remove them, hopefully you can go up one size to install the new sender.
Call centroid, they are nice to deal with. You need to give them tank depth and gauge resistance. When I replaced mine, I also replaced the gauge with a new KUS gauge.
- Has thanked: 603 times
- Been thanked: 1311 times
- Hold'n On II
- Vessel Info: New to us 1996 370 Voyager
- Been thanked: 11 times
I'm installing one of these on my waste holding tank on our '96 370 Voyager, which never had a level indicator.... .. plan to do the same on our fresh water tank(s).
https://www.fisheriessupply.com/scad-te ... itor/10040
- Been thanked: 1113 times
Hold'n On II wrote:Source of the post Remove, cap and seal the opening, or simply disconnect and replace with an external sensor & monitor.
I have a similar "outside the tank" sensor monitoring system made by Tech-Edge. I have an extra one for a project I didn't end up doing, if anyone is interested in adding that kind of monitor to their vessel. It does multiple tanks and has customizable alarms.
(it's the iSeries: https://tankedge.com/products.html )
Users browsing this forum: Google [Bot] and 38 guests
