466 midship cleat loose
Tbw5959
Vessel Info: 2004 466 M/V Salt and Light
Volvo TAMD75's & Kohler 20kW generator
Has thanked: 39 times
Been thanked: 4 times
Postby Tbw5959 » September 7th, 2021, 1:33 pm
Survey last week on a prospective 2004 466. Discovered aft midships cleats on both sides a little 'loose' - i.e., when the surveyor rapped them with his hammer, the cleat would rotate off center a little bit; and then when rapped on the other side/end, the cleat would rotate back the other way, just a smidge...
I'm wondering if anyone else has tackled this issue on a 466 and can offer some words of advice on how to get in to the back side (i.e. backing plates side) of those?.... Thanks
Been thanked: 1310 times
Re: 466 midship cleat loose
Postby bud37 » September 7th, 2021, 4:31 pm
I don't know specifics of your particular boat, but, what did your surveyor say, are there gel coat cracks around the fitting that could have been caused by dock lines and wind and the cleat moving around....was there moisture there. If you can see machine screws then these may just be screwed to a backing plate buried in the glass below. Hopefully someone that has some proper info can chime in.
In the meantime seal it up until you can find out what is going on.....good luck with your purchase.
