Navigating in salt water with Crusaders
JimCarver
Vessel Info: Carver Mariner 360 2004. 650 hours on the 6 liter Crusaders gas engines. We've owned the boat since June 2021.
Postby JimCarver » September 13th, 2021, 4:06 am
Hello,
My home port is in Gananoque, Ontario where my 360 Mariner with Crusader engines has ran in fresh water its whole life (650 hours). I'm considering navigating to South Carolina for the winter and spending 5 months in salt water, and was wondering if my engines are made to run in salt water or not.
Since my engines use Prestone, I believe they're closed cooling.
Your answers are very much appreciated.
Re: Navigating in salt water with Crusaders
Postby Viper » September 13th, 2021, 7:15 am
Having a "closed cooled" or "fresh water cooled" (coolant filled) block is what you want, the question is whether your exhaust manifolds are closed cooled. If they're not, it's not a deal breaker but they're life will be shortened running in salt water. The typical benchmark to start worrying about their condition in salt water applications is 5 to 8 years. That doesn't mean automatic replacement at that point, it's just something you have to keep in mind and consider adding periodic inspect as part of your overall maintenance schedule. When ignored for too long you're running on borrowed time and a failure can be catastrophic for the engine.
uchu
Vessel Info: 1988 Carver Santego 2767 - Twin Mercruisers 4.3LX with Alpha-One drives
Has thanked: 86 times
Been thanked: 15 times
Postby uchu » September 13th, 2021, 9:53 am
We're talking about a roughly 1,200 mi. trip, each way. Hopefully you'll give your boat a thorough inspection before undertaking such journey! It certainly requires careful preparation.
Postby g36 » September 13th, 2021, 10:56 am
That sounds like a great trip
Been thanked: 1112 times
Postby km1125 » September 13th, 2021, 11:40 am
I'm jealous. Sounds like a great plan.
The engines will be fine with some saltwater, but just note Viper's comments.
Bring plenty of spares for the trip (impellers, filters, etc) because just saving a few hours instead of waiting for parts can save you days in the commute and avoid a lot of frustration.
Been thanked: 285 times
Postby buster53 » September 13th, 2021, 4:36 pm
Even if you have fresh water cooled engines, you still have a raw water side. On my boat, all of my sea strainers have connections that I can hook up a fresh water hose to. In a manner of minutes, I can flush my engines, genset and AC system. Makes winterizing a breeze as well.
BTW, many, many thousands of Crusaders have and are being used in salt water and have been for years. I would say the vast majority are fresh water cooled which extends the life of the engine.
JimCarver
Postby JimCarver » September 29th, 2021, 8:05 am
Thank you viper, buster53, km1125, g36 and uchu for all you comments and answers!
