Replacement deck lighting 380 Santego 1994
- Walt
- Vessel Info: 1994 Carver Santego 380
454 Crusader XL
Lake Ontario - Location: Toronto Canada
- Has thanked: 3 times
Any advice welcome.
Walt
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Replacement deck lighting 380 Santego 1994
I bought my festoon style from superbrightLEDs.com and my halogen style from Amazon.
A couple other companies… marinebeam.com and doctorLED.com and plenty of others.
I replaced all my bulbs with LEDs bought on Amazon.ca. Take note of the type of bases the bulbs have and search the web for base types to get a base number. This will help narrow your search for the correct bulb. I had about 4 different bulb types to replace on mine. If dimmers are involved just look for ones that specifically say they are "dimmable", put that in the search title along with the bulb type. Look at the ratings and customer feedback, that will give you some idea of their quality, and you get what you pay for so if it seems too good to be true, it probably is. You'll also typically want to choose either cool white or warm white. I went with with cool white in the heads and warm white throughout the cabin. Are yours halogen bulbs or regular incandescent?
- buster53
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
“Escape Plan”
Murray, KY
- Walt
454 Crusader XL
- Walt
454 Crusader XL
- buster53
https://www.amazon.ca/Dream-Lighting-Recessed-Interior-Caravan/dp/B0105KS95C/ref=sr_1_1?dchild=1&qid=1632994857&refinements=p_89%3ADream+Lighting&s=automotive&sr=1-1
Dimming! In order to dim led lights one must have access to both positive and negative leads going to the fixture. Unfortunately boats are wired with the positive lead switching which means you only have access to 1 wire in most cases at the original switch. If you can track down the negative side then yes it will work however I know in my salon this had me scratching my head and left it stock for another day when I feel like really getting into it.
Users browsing this forum: geo and 43 guests
