1995 390 cpmy Hull construction
Georgeviking
Vessel Info: 1995 390 cpmy
1978 32’ Uniflite sport sedan
1968 31’ ulrichsun
1968 31’ broad water
1977 19’ checkmate
1975 17’ west wind.
Has thanked: 4 times
Been thanked: 3 times
Postby Georgeviking » September 28th, 2021, 7:06 pm
Is it me?? But for the life of me I can’t get a straight answer on is this a solid fiberglass Hull
Or is it cored ? I’m about to make a purchase and it will be a bit taxing on us but we so love the layout
Just can’t find if sides are cored past water line is the transom cored past the water line
Stated that you could go by model to know think ending in 7 or higher meant solid and lower meant cored well at 390 I don’t know if 0 is good or bad lol. Any info would be so appreciated :banghead:
Been thanked: 601 times
Re: 1995 390 cpmy Hull construction
Postby tomschauer » September 28th, 2021, 8:21 pm
a 1995 390 should be solid glass below the water line.
Your decks will be cored, not sure about the transom.
Many boats are cored, even some new million dollar plus boats. Its not an issue unless the core gets wet.
Have a good surveyor check the boat.
Been thanked: 646 times
Postby g36 » September 28th, 2021, 9:22 pm
Here's a very nice review on the 390. As stated above it is solid fiberglass hull balsa cored top sides.....https://dicksimonyachts.com/blog/boat-r ... terthought
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » September 30th, 2021, 5:41 pm
Welcome aboard
Georgeviking
1968 31’ ulrichsun
1977 19’ checkmate
1975 17’ west wind.
Postby Georgeviking » October 18th, 2021, 11:42 am
Thanks viper we actually wound up purchasing the vessel, on my second look was fortunate to find original owners manual where it proudly stated the Hull was indeed solid glass. Just a bit more piece of mind lol
Been thanked: 406 times
Postby Cooler » October 18th, 2021, 12:06 pm
And, the depth of the fiberglass was measured multiple times while the hull was being hand laid. No way there could be any shallow areas. Too bad we don't have access to the build logs anymore, or you could have secured that data. No issue with hull strength, unless it was damaged any subsequently repaired at some point. 8-) er
Netherlands
Sailor Robbert
Vessel Info: Carver 390 CPMY 1993 with 250 HP
Cummins Diesel
Has thanked: 19 times
Been thanked: 11 times
Postby Sailor Robbert » October 24th, 2021, 7:56 am
Georgeviking,
I have a PDF file of the owners manual but too big to attach here.
If you want it send me an email and I will forward to you
uittenbosch@planet.nl
Carpe Diem :pirate: :captain: ;-)
