Heating/AC to Fly Bridge?
Topic author
dirtdoc1
Vessel Info: 2013 Carver C34
Postby dirtdoc1 » January 5th, 2014, 12:17 am
Has anyone figured out a clean way to run heat/AC to the fly bridge? Maybe the bigger Carvers already have that but I'm getting a baby C34 in a couple of weeks and I'm concerned about freezing my ass off in the winter. I boat year round and in my 25' Skip Jack sport cruiser the engine covers were in the cockpit where the helm was. With the canvass completely enclosing that area the heat from the engines kept it nice and toasty even on freezing cold days. I'm concerned about being up on the fly bridge even with a complete enclosure. :captain:
Any thoughts would be greatly appreciated.
One Cold Captain
Has thanked: 64 times
Been thanked: 481 times
Re: Heating/AC to Fly Bridge?
Postby waybomb » January 5th, 2014, 9:39 am
Webasto may make a heater running on fuel you could use. They also make small A/C units that you may be able to squeeze in somewhere. Youd jhave to figure out a path for the water hoses though.
I've read that Carver had installed resistance heaters in some of the ir boats earlier, like in 2005 or so, as cabin heaters instead of using the revrese mode on an ac unit. Maybe you could call Carver and find out what units were installed. I would guess thay are boat-safe. May need to increase your electric service to do so.
MissWhit's
Location: Eisenhower yacht Club, Lake Texoma, Sherman TX
Been thanked: 4 times
Postby MissWhit's » January 6th, 2014, 5:51 pm
DirtDoc1,
I had a 3075 Cruisers and I wanted to heat the cabin without running the reverse heat unit as it was loud while running. I installed a wall mount BROAN bathroom heater in the cabin right under where the seating was and it worked very well. In the C34 you might consider using two units spread across the area and as long as you have cavity space at the mounting location they will fit as they only have about 4-6 inches of mounting depth. Are they safe? I see why not as you are not in a flammable area like an engine compartment and they do not emit carbon monoxide either. Check with your local Lowe's or Home Depot as this is where I purchased mine. I do not believe the current draw is too high either so you might get away with running 10awg from the power panel to the two units but check with your local licensed electrician first. If 10awg is not large enough then you might be able to run 8awg to one unit then split off with 10awg for the second unit. Another consideration is the length of wire run from the shore panel.
MissWhit's
Lake Texoma, Denison TX
Port: EYC Marina
2001 406 twin 380HP 454 MPI
Topic author
dirtdoc1
Postby dirtdoc1 » January 11th, 2014, 8:51 pm
Thanks for your suggestions I will follow up on them. I was watching different videos of the C34 Fly and noticed in one of the videos that there was what looked like a vent/register at the upper helm. My guess is that if you get the A/C option they run a vent to the upper helm. I may not have to worry about it after all. I will find out soon enough. The boat is being shipped next week but will have to spend some time in quarantine due to the CA importation rules regarding mussels. If you are bringing in a boat that has been in the water they want to make sure that any mussels that are attached to the hull are dead so as not to contaminate the CA waterways with animals not native to the area.
Cheers!
