Replacement LED 12v Salon Ceiling Lighting Pucks
Original Hera Brand Fixture, Discontinued Many Years Ago. https://www.eclectic-ware.com/hera-repl ... parts.html
Problem with these is the heat from the halogen bulb dries out the plastic until it crumbles by touch, not worth buying used ones or trying to find new ones as the plastic is probably so old they will not last.
Not sure who posted this but I did find this on this site several years ago and can confirm it is a direct replacement, all LED light fixture. I guess there was so much demand someone decided to make a carbon copy of the size/style. I did find out several RV manufacturers also used these in the past and have the same issue with deteriorating plastic.
So here is the newer kid on the block, called Dream Lighting. These will fit into the existing holes once the Hera units are removed. The only difference is the Hera units did not care if they were connected in any way as polarity on incandescent/halogen does not matter. LED are not the same and you need to get the polarity correct for them to work. No worry as they are "polarity protected" meaning just try one way and if the do not light up, reverse the leads and it should light up and you are done.
TheDream lights still are plastic however without the heat from the halogen bulb and being away from UV light (sun) I suspect they will last the lifetime of the boat, time will tell.
Dream Light LED Light/Fixture. https://www.amazon.com/Dream-Lighting-Recessed-Ceiling-Silver/dp/B00S4CPL5U?pd_rd_w=OQY2y&pf_rd_p=bcca84ef-5f4d-4682-852e-b0b38f16e8ba&pf_rd_r=SNGQ3WHQF50CCWT8QG3K&pd_rd_r=81b1cd65-efe2-4006-99c3-5e6c53848717&pd_rd_wg=M2wxn&psc=1&ref_=pd_bap_d_csi_pb_allspark_BIA_0_t
Today I came across another light which also seems to be the same size and another copy of the Hera size. I have not tried these however hopefully someone here will and confirm fitment in the Hera hole on the boat. These are made of machined aluminum, the lens cap screws off and have metal clips on the side to secure them in place via friction. Thought I would include these as they may be a great alternative to Dream lights.
"Aloveco" Aluminum 3W LED Light/Fixture. https://www.amazon.com/Recessed-Waterproof-Ultra-Thin-Interior-Motorhome/dp/B07B8B2XJ7?pd_rd_w=NWrte&pf_rd_p=bcca84ef-5f4d-4682-852e-b0b38f16e8ba&pf_rd_r=RMP2Z68E2BAT3PNH8465&pd_rd_r=d08469e2-7308-418c-bd60-87655baec1e3&pd_rd_wg=CwRjH&pd_rd_i=B07B8B2XJ7&psc=1&ref_=pd_bap_d_csi_pb_allspark_BIA_3_t
Note to Admin, would be nice to make this a sticky as this is asked way too frequently.
- wkeith
- Vessel Info: 2004 Carver 466 Aft Cabin MY
- Has thanked: 8 times
- Been thanked: 14 times
Re: Replacement LED 12v Salon Ceiling Lighting Pucks
Thank you,
Walter
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
As a reminder, if your old fixtures are still in decent shape, replace those HOT halogens with much better LED’s. I replaced at least a dozen on my 356. Slightly brighter, much cooler, way more efficient and probably will never have to be replaced as they last thousands of hours.
If I recall, I paid less than $15 for a pack of 10.
- Coldcruisin
- Been thanked: 7 times
- M. Cote
- Vessel Info: 2000 Carver 350 Mariner, twin Mercruisers 7.4 L MPI’s
- Has thanked: 1 time
Mike.
