Kohler 21KW genset heat exchanger Anodes
Carpediem
Vessel Info: In process of buying 2000 506 with Volvo TAMD 74s
Been thanked: 25 times
Postby Carpediem » December 23rd, 2021, 12:12 pm
In doing my annual service/inspections I noticed a couple of things that gave me pause. I have no Anodes on the fresh water heat exchanger on the engine for the gen set and there is no green wire bonding to the boat's anode system like the main engines have. Does anyone know why this is not the case? On my Sea Ray 44DB with an Onan genset there was an anode in the fresh water exchanger. I don't recall whether the genset chassis was bonded
or not.
Carpe Diem
Try to only boat where ducks don't walk
Tbw5959
Vessel Info: 2004 466 M/V Salt and Light
Volvo TAMD75's & Kohler 20kW generator
Has thanked: 39 times
Been thanked: 4 times
Re: Kohler 21KW genset heat exchanger Anodes
Postby Tbw5959 » January 5th, 2022, 12:23 am
Carpe,
Is that genny a Yanmar engine? FWIW, our Kohler 20EOZ is a Yanmar engine & we went thru the same thought process to learn -- Yanmar didn't design an anode into it. Saw this previously on a much smaller Yanmar also (3YM30).
Carpediem
Postby Carpediem » January 5th, 2022, 6:13 pm
I'll have to look and see in the manual which engine is used.
Users browsing this forum: No registered users and 4 guests
