Engine switch out
Topic author
Hlamkuo50
Vessel Info: 1979 carver mariner 351w
Engine switch out
Postby Hlamkuo50 » April 30th, 2013, 4:58 pm
Hey everybody I have a 79 mariner w/ 351w I was wondering if I could install a 350 instead
Been thanked: 490 times
Re: Engine switch out
Postby waybomb » April 30th, 2013, 7:32 pm
How much do you want to spend? Talk about alot of work. If the 351 w is tired, rebuild it. You'll be many dollars ahead.
Dpoelstra
Postby Dpoelstra » May 21st, 2013, 6:21 pm
These are different engines and nothing will bolt up. Anything is possible with enough money. Why would you want to change from Ford to Chevy?
Dan
"Brown Eyed Girl"
1981 Carver 3007 30ft. Aft Cabin
Huntington Harbour, Ca
"But why's the rum gone....?"
