Under Platform Swim Ladder
- MichaelOKC
- Vessel Info: 1989 Carver 3467 Santego
- Has thanked: 17 times
When we pulled the boat out, year before last, to have the hull cleaned and treated, no one mentioned any issues concerning the ladder. Also, I do not know if this ladder configuration is a common feature on Santegos. I might also add that I wish it had a few more steps. For a while, I had wrapped a bungee around it, but that was apparently a temporary fix. I presume there is/was some kind latch mechanism that has failed. Also, the fact that I cannot see what is wrong without a mask and goggles means a wait for warmer water, or until the next “bottom job.” Maybe just get another bungee cord? Thanks for your suggestions.
Re: Under Platform Swim Ladder
Back to a failed latch mechanism you mentioned. In the past how did you deploy it? Must have been something you needed to do to unlock it. If it is like mine with the red button then the ladder needs a good swift final push to engage the mechanism other wise it may not lock and may deploy on its own after travelling. This is what the ladder looks like, does yours have a red button on the end like in the link? Not sure if this is what Carver used or if it is a copy cat Chinese brand. https://www.sealuxpro.com/SeaLux-Pop-N- ... ing-Ladder
- Rocketman
- Been thanked: 24 times
I used a small bungee cord for a while until I could replace with a new 4 step ladder that has a latch.
By the way, my wife loves the new 4 stop so she does not have to struggle so hard to get out of the water.
I did replace mine in the water but it was a royal pain as I have pods and could not get close enough to the bank to stand. I had to do it from a large tow raft. Used some of the original holes but had to drill some new ones.
My swim platform has an aluminum plate sandwiched into the fiberglass swim platform that I had to drill thru and use large SS hex head metal screws to secure.
- MichaelOKC
