General Rudder gap question
rvannan
Vessel Info: 1993 Carver 350AC
Postby rvannan » January 23rd, 2022, 10:55 am
93 350 AC - Noticed when boat was pulled for storage (first year of ownership) that there is about a 1/8" gap between rudder and mount. Same on both rudders. Just curious if this is expected and through shaft is designed to float a bit? Advice much appreciated!
Been thanked: 1111 times
Re: General Rudder gap question
Postby km1125 » January 23rd, 2022, 2:51 pm
As long as there's some gap I wouldn't think it would be an issue. You wouldn't want too much or all that stuff inside is going to be moving around a lot.
Postby Viper » January 24th, 2022, 10:00 am
Ya that's a totally normal gap. You can get away with a little more but only if all the attaching hardware is in the proper place, tight, and doesn't have excessive ware. It's okay to have a little vertical movement but not much depending on the type of system. There shouldn't be any lateral movement/slop from side to side.
rvannan
Postby rvannan » January 29th, 2022, 10:40 am
thank you Both
