crusader 270 distributor issue.
- ataylor233
- Has thanked: 83 times
- Been thanked: 7 times
- Been thanked: 654 times
Re: crusader 270 distributor issue.
- ataylor233
g36 wrote:Source of the post The yl624av would work fine the sierra like you had pointed out ....https://www.summitracing.com/parts/rra-18-5313-1. It's still a points distributor if you went with a ylm624 it would be magnetic and no points to worry about anymore. If you can find it but heres a sierra equivalent https://www.wholesalemarine.com/sierra- ... mXEALw_wcB
Thank you this was helpful
- Has thanked: 603 times
- Been thanked: 1311 times
- ataylor233
- Been thanked: 1113 times
Also, did you double-check the firing order and the plug wires that are attached to the cap?? (again - more than once I've made THAT mistake!!)
Did you do a static timing (put crank at ~10BTDC and rotate the dist until you get spark, then bolt it down) or check timing with a timing light to see if you're somewhere in the ballpark?
- ataylor233
km1125 wrote:Source of the post Sure you're at TDC of the COMPRESSION stroke?? More than once I've made that mistake!!
OK i figured out my timing is way off I got it to start by rotating the distributer almost 90 before it fired up and cut back off.. So I got a little bit more to figure out. But I think I will be fine
