Virtrifigo Fridge swap out
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
Thanks!
Tony
- Been thanked: 1113 times
Re: Virtrifigo Fridge swap out
But, if you really can't get to it, then there would be no problem with just reusing the old cord and wiring it to the new unit.
Yes, you could run the condensate just into the bilge, but you might want to see if you can get it to a shower sump or even the drain pan of a near HVAC unit (which should run into the shower sump) so you don't have unnecessary water in the bilge that could just complicate trying to find a real leak into the bilge.
- tonyiiiafl
Midnightsun wrote:Source of the post Just curious, are larger boat fridges different? Never seen a fridge that requires drainage, even the biggest units for home use. Normally they simply use a drip tray which allows the water to naturally just evaporate on its own. They are typically located over the compressor where the heat helps the evaporation process.
I've not had one personally, but I've seen several models when I was looking for one that did have a drain. That would be great especially when you spill something in there or have to defrost it.
- tonyiiiafl
- Been thanked: 654 times
- tonyiiiafl
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
There should be no drain on these refrigerators.
For what its worth.
Greg
- tonyiiiafl
