erWelcome to Carver Yachts Owners Forum
Opinions on partner ownership
- Cooler
- Has thanked: 68 times
- Been thanked: 406 times
- Has thanked: 78 times
- Been thanked: 1093 times
Re: Opinions on partner ownership
My first boat was a partnership with a friend. That worked out great for the first several months, but then my job transferred to a different state so I didn't get to use the boat much. He (graciously) took over all the financial obligations since he was using the boat more than I was, but I still had an ownership stake. The following year he hadn't been using the boat much mostly because the weather sucked and the season ended and the boat ended up in winter storage. Then, weirdly, I took a new job back in the state but he took one out of state. The boat sat in storage in that intervening year. When I got to re-launching the boat I found that there was also not much maintenance being done and ended up doing a major restoration on it (not all of that was due to lack of maint though, as it was an older boat). I ended up putting a lot of money and time into the restoration and (obviously) didn't recover that when it eventually sold, so there weren't much proceeds to split.
As in most cases of split-ownership, we should have had a much more thorough understanding of the maintenance and expenses and how they would be covered. But, it was the first boat either of us had ever owned and we really didn't know what we were getting into either.... it was just for fun.
Had a dock neighbor that had joint ownership on a sailboat and their logic was that it was better because they'd both be sailing it together. Didn't happen much, as the one guy was busy with work and the other guy was retired. They didn't end up using it anywhere near they had anticipated, but the retired guy ended up spending a lot of weekdays on it just relaxing and 'putzing' fixing things up on the boat.
- Has thanked: 598 times
- Been thanked: 1281 times
So a question if I may, if you aren't needing to do this for money then........
- Been thanked: 601 times
The wrong partner may run the boat a lot harder than the other, and sometimes "forget" to top off the fuel, pump out the holding tanks, check the oil etc. For me, i know what condition my boat will be in when i park the car at the marina. I don't want the surprise of empty fuel tanks, or worse, full holding tanks when you arrive after hours for the weekend!
Then you have the issues of repairs. lost an engine? If you owned the boat previously, your partner may say he or she bought into a problem. If you bought it together (I believe this would be the best way) then it is a matter of do you both have the money to split the repair, or make the decision to cut your losses and sell. If you buy an older boat and an engine or engines fail, it may cost more to repair than the boat would be worth. Is this addressed in your partnership agreement?
A whole lot of things to consider.
Three or four seasons ago we had a new slip neighbor. He had partnered with a friend on a Trojan (I think an f32 or 34?) the partner that originally owned the boat was seldom seen. Between the two of them, prior to moving into our marina, did a great job restoring the late 70's trojan. It looked as new. The partner that was on the boat every weekend was new to boating. The first weekend there he couldn't get the a/c to work and asked if i could help. Sure, no problem. I went into the salon, he showed me the nice new carpet he installed. Unfortunately, he installed it as you would in a house, stretched tight with perimeter tack strips. He covered all of the access hatches!!! He didn't think there was any reason to get in there!! He pulled the carpet, and I purged his a/c line and go that working for him, but it was all downhill from there.
I will add two examples, there were many more, and no, I am not making this up.
We are on the Sassafras River off the Chesapeake Bay. One trip he made to go for dinner in Havre de grace (about 25 miles each way) he made it almost back to the marina and had to be towed in. Told me he didn't know what happened, the boat was running fine and then just died. I asked if he ran out of gas. He said no way, he put 30 gallons in before the trip. A couple of 5-gallon cans and he was able to get the fuel dock.
Another similar trip, about five miles further each way, he came back to the marina on one engine. Said everything was running well at about 5000 rpm's when a buzzer kept sounding on the bridge. No, he didn't back off, kept going, didn't know what the buzzer was. again, somehow, almost made it back but was towed in again. Next day he said something was wrong with the one carburetor, because when he ran the engine, it spit out oil, and there was a lot of oil in the bilge. I told him he blew the engine, but that was not possible as they were brand new.
I just listed the first and last incidents, there were several in between. After the last one the boat disappeared, and we have not seen it since.
- Has thanked: 469 times
- Been thanked: 1765 times
- Cooler
- Cooler
Return to “Boating & Cruising Lifesyle”
