Repair and Charge Cruise Air
- ontariojeff
- Vessel Info: 2003 Carver 570
- Has thanked: 2 times
I have two cruise air systems and both seem to be loosing coolant.
I think the leak may be out of the pressure fittings.
I have seen a product that claims to be some sort of "stop leak" fluid. and another product to locate or "smell" for leaks.
I am thinking of soldering or fixing the leaks and then re charging the system.
R22? and some gauges.
Any advise on how to go about this?
Thanks.
- Been thanked: 1113 times
Re: Repair and Charge Cruise Air
Is it R-22?? That's starting to get pretty expensive.
You can use a refrigerant leak detector as mentioned, or simple soap bubbles are usually the best. You need to find the leak, recover the r-22, purge nitrogen through the system while you braze the leak (if its repairable), then evacuate the system and charge the new r-22 by weight.
Before you do all that what makes you think your systems are leaking?
- ontariojeff
I had the larger one filled $350 and the smaller one $450 !!
they lasted less than one week. My thermostat is reading
"low ps" again...
Although I have read that you need a to take an online license to buy r22, Ebay has 5 lb. full tank for $300 and a 10Lb tank for $360, don't seem to need a license to order.
and a gauge set for $60.
I was quoted $3,600 to remove a unit, solder up the fittings leak and re install it!
So I'm considering it a "no brainer" to attempt this myself.
I am wondering about how much coolant and what pressure to use? 50-70?
ontariojeff wrote:Source of the post
<snip>
Offhand, not sure on the pressures, but the amount of refrigerant would likely be 16-28oz. Many have that listed in the specs on the attached sticker.
Look and feel around any connections at the condensers and evaporators for oil and dirt. Start there with a soap bubble test. You most likley have flare connections at both ends. That is the best place to start.
