Fuel Transfer
- jema
- Vessel Info: 1991 Carver 430 Aft Cabin. Twin Cumins 6BTA 5.9
Fuel Transfer
I cant seem to get a clear answer on how to use this. On another forum it was suggested the transfer pump will be on the bulkhead behind the generator. Mine is still shrink wrapped so I havent been able to confirm. My question is about the operation. Is it as simple as flipping on the breaker to start the process or are there diverter valves that need to be switched around. Im not asking about using the rear auxillary tank. Just asking specifically about the cross over. Hopefully someone with direct experience can answer this for me. Thank you.
Re: Fuel Transfer
https://www.greatlakesskipper.com/carli ... -on-off-on
That being said I also have 2 auxiliary tanks however transfer between them is not possible or between main and aux tanks. To select main or aux to supply the engines, there are a couple of manual valves clearly marked in my engine bay.
If you want a switch like the one I linked to, better pick it up as they show 7 remaining which are probably have the last 7 available in the world.
- jema
Re: Fuel Transfer
Re: Fuel Transfer
- jema
Re: Fuel Transfer
- Carpediem
- Vessel Info: In process of buying 2000 506 with Volvo TAMD 74s
- Has thanked: 2 times
- Been thanked: 25 times
Re: Fuel Transfer
RM
- jema
Re: Fuel Transfer
- womide
- Vessel Info: 2022 Toyota Corolla Cross
- Has thanked: 8 times
Re: Fuel Transfer
