454 Gen 4 lifting ring
Petemait
Vessel Info: 1983 Carver Riviera
Has thanked: 56 times
Been thanked: 18 times
Postby Petemait » May 7th, 2022, 9:46 am
I am taking out my generation for generation for crusader 4 54 to be rebuilt.. One of the lifting rings is missing. The existing ring is installed on the starboard side of the engine towards the Stern. Does anyone know if the other ring should be installed at the opposite side of the engine so port side towards the bow?
In the attached picture you can see the existing ring and you can see where I took a bolt out to go size it next to the number one cylinder. Does anything know if this is the correct location for the ring? Had trouble finding information on it, online.
Thank you in advance
Looks like the picture isn't going to upload. The existing one is next to the number 8 cylinder starboard sternmost cylinder. Port bow most cylinder is number 1. Any help is much appreciated
Pete
1983 Riviera 2807
Boston, MA
