Carver 41 Cockpit Motor Yacht.. Where is the waste water tank switch?
- Gerard Chuah
- Vessel Info: Carver 41 Cockpit Motor Yacht 2006
I have a 2006 Carver 41 Sport Motor Yacht
My aft waste water tank is full and for the life of me, can't find where the switch to empty the waste water tank! Is it on the main AC or DC control panel?
Or in the engine room?
Much appreciated for your kind help
Email me directly at gerard.chuah@gmail.com
Best regards
Gerard Chuah from Singapore
Re: Carver 41 Cockpit Motor Yacht.. Where is the waste water tank switch?
If you have a pump, the breaker would be in your DC panel labeled "waste pump" you would also have a switch at the pump so you can't accidently discharge waste. Also, if you have two tanks, there would be a Y valve near the pump to select which tank to empty.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
tomschauer wrote:Also, if you have two tanks, there would be a Y valve near the pump to select which tank to empty.
If you have 2 tanks, most likely each will have its own deck discharge fitting.
Agree it’s a good chance you don’t have overboard discharge as it is illegal to do so unless you are outside the 3 mile coastal limit.
Agreed on the deck pump out fittings. But if he does have an overboard discharge pump, usually only one pump and one thru hull with a Y valve before the pump.
No clue what the waste dump laws are in Singapore however most places dumping is restricted too far off shore in the ocean. If it is restricted in your area, a pump out facility must be available at most marinas.
I changed the labeling with a P touch so Macerator cannot be seen however this is the panel I am referring to. I belive it was on the left hand side where I labeled them spares.
- AndiamoSeattle
- Vessel Info: 2006, Carver 4137 CMY, Originally commissioned in 2008, it has spent its last 10 years in the Puget Sound, WA. She features the Volvo-Penta D6, 310 diesel motors (485hr.), 3 zone AC/ Heat pumps, fresh water wash down in bow, bow and stern thruster, 8.0KW Kohler generator, 2/ 30amp shore power input from either mid-ship or stern plugins. Bridge refrigerator ice maker, electric galley featuring an electric oven.
- Has thanked: 50 times
- Been thanked: 2 times
