SeaStar hydraulic steering
danclev
Vessel Info: 2007 Carver 35 SS
Has thanked: 17 times
Been thanked: 3 times
Postby danclev » May 16th, 2022, 7:00 pm
Noticed my steering started feeling chunky then felt like I lost it altogether while underway at one point, then came back for me. Clearly the system has a leak and will fill + bleed. But looking at the fitting it looks like the source of the leak, but I'm not seeing a volume of fluid just some spray.
Does this look like it's a simple repair or replace the cylinder in full?
Dan
Re: SeaStar hydraulic steering
Postby Viper » May 16th, 2022, 7:21 pm
It should just be a tee fitting where the hydraulic hose attaches to one end and the other end with the red plastic cap is the bleeder. What end is leaking or is it leaking where the tee meats the cylinder? If the bleeder is leaking, make sure the bleeder is closed tight. If it can't be tightened enough to stop it from leaking, replace the bleeder.
Users browsing this forum: Matriarch and 53 guests
