Water Maker Booster Pump
Topic author
mikekomm
Vessel Info: 1989 4207
Postby mikekomm » February 9th, 2014, 11:12 pm
My 1989 Carver 4207 has a water maker that was using a Vantage Marine booster pump that has gone south. Both the motor and pump look to be rusted solid. Anyone know what might be other sources than Vantage marine to buy a replacement motor/pump? It's just a Baldor motor with a pump mounted on the end.
MissWhit's
Location: Eisenhower yacht Club, Lake Texoma, Sherman TX
Been thanked: 4 times
Re: Water Maker Booster Pump
Postby MissWhit's » February 12th, 2014, 11:25 am
Mike, Attached is a link to Baldor and they have a where to buy button. http://www.baldor.com/default.asp. I would bet the motor is not special and considered "off the self" and using the data plate you should be able to match it up. Baldor motorsnore sold in so many places it is impossible to recommend just one. I have even found used ones on EBAY that had no problems. The big issue you will face is the pump that is bolted on the end. Hope there is some sort of data on it somewhere.
MissWhit's
Lake Texoma, Denison TX
Port: EYC Marina
2001 406 twin 380HP 454 MPI
Thomasberry
Postby Thomasberry » April 21st, 2015, 3:39 am
You can repair that pump, but if you get the overall pump replace then it would be much more better. I agree though the motor and the pump is little expensive, but it will be good if you replace it.
Wzdr02
Vessel Info: 1988 Carver 4207 w/CAT 3208TA
Postby Wzdr02 » October 23rd, 2016, 10:23 pm
What kind of water maker? Where were all of the components located? Pictures please??
