Heater pops the circuit and wont stay on
- terkim99
- Vessel Info: 1987 3807
- Has thanked: 3 times
- Been thanked: 1111 times
Re: Heater pops the circuit and wont stay on
Now, the actual issue. Was there water flowing when any of the three systems were running?? You need water flowing through the system to transfer the heat (or cold) to the lake. If the seacock wasn't opened yet, or the system not primed, then no seawater will be flowing and none of the units will provide heat or cold (well, they might work for a few minutes, but then shutdown).
Have you used the units before in either heat or cooling mode THIS YEAR yet, or was this the first time?
- terkim99
To be clear, I'm talking about the seacock for the HVAC and if water was coming out the exit ports for each HVAC unit. If the strainer he cleaned was for the HVAC, did he re-prime the system after to make sure water was flowing?
- Has thanked: 602 times
- Been thanked: 1310 times
Keep us posted.
The first thing I would check is the voltage on shore power line 2 and the condition of the power cord ends and the boat's inlet. If any area of the plug around the contact prongs is discolored or melted, the cord and or pedestal and inlet are suspect. Try using a different cord and pedestal and see if you get a different result.
- terkim99
