1988, 3807 propeller issues
- VicB
- Vessel Info: 1988 Carver 3807
- Has thanked: 41 times
- Been thanked: 11 times
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: 1988, 3807 propeller issues
Is this a new to you boat? Did it run like this during sea trial? Did the surveyor make any comments about the low RPM’s? Did you question the seller about it?
- VicB
- buster53
How do you run the boat…what speed to you cruise at? I used to have the same boat and while cruising speed was in the 15-16 mph range, we normally ran at hull speed, about 8-9 mph to save on gas.
- VicB
- VicB
- Been thanked: 1111 times
I would **NOT** suspect a prop size issue unless there was some indication they were changed previously (as in 'mentioned by the previous owner' or something like that), or I ruled EVERYTHING else out first. People wouldn't typically go to a larger prop on a boat like this unless they spent ALL of their time at hull speed and wanted more of a trawler.
When you checked the timing, did you check the mechanical advance?? Do your distributors have mechanical advance of is the timing advance done electronically?? Whether done mechanically or electronically there must be advance as you go up in RPM or you will NEVER be able to achieve rated power on the engines.
Checking the mechanical advance is fairly easy, as you just remove the dist caps and rotate the rotor. In one direction you should be able to twist it and have it 'snap' back to the original position. If you can't twist it or it doesn't snap back easily, then the mechanism is likely rusted. If it's electronic advance, there's usually a pin or connector that will disable it so that base timing can be set and if that pin or connector is not restored you won't have advance functioning.
You can verify how much advance by using a timing light and measuring the timing across RPM ranges to see that it increases with RPM and comparing with spec.
Also, not really related to this issue, but those anodes on the tabs should be on the TOP side of the tab. Putting them on the bottom just increases drag on the boat.
- Has thanked: 602 times
- Been thanked: 1310 times
There are some members here with the same boat as you, hopefully they can be of more help as to speeds at certain rpm's.
- VicB
- buster53
