1996 Carver 355 aft cabin
- derekbmouzon
- Vessel Info: 1996 Carver 355 Aft cabin
- Been thanked: 654 times
Re: 1996 Carver 355 aft cabin
If your having problems with creating enough vacuum or the system wont ever cut off you could look at changing these then . The duck bill valves are at the hose inlet and exits at the vacuflush vacuum generator. In my 405 aft cabin the generator is under the floor out side the entrance to the head. Yours would probably be close by also. Look under the hatches in bedroom.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
- derekbmouzon
. I wanted to identify what model I had as I’m unsure so I can order the parts. I also may consider total replacement from the noisy push button model I have. See attached photos.- tomschauer
- buster53
