Grey Water Tank hose access
DLOtten
Vessel Info: Carver 450 Voyager
Postby DLOtten » July 3rd, 2022, 1:59 pm
:banghead:
I have a 2002 Carver 450 Voyager.
I have a grey water tank draining into my aft bilge.
The connection at the discharge port is solid. Same at the grey water tank. From the discharge port, the hose disappears into a tunnel and I can't find any other access to it until it hits the tank. Any ideas on how to find/access this leak.
Coldcruisin
Been thanked: 7 times
Re: Grey Water Tank hose access
Postby Coldcruisin » July 7th, 2022, 8:04 pm
Whre is your tank located? Mine is in the floor of the master. Make sure your sump switch is on in the engine room. If not, the tank is designed to overflow into the rear bilge where the bilge pumps will eject the overflow.
DLOtten
Postby DLOtten » July 8th, 2022, 10:41 pm
Thanks. Mine is also in the master. I hear the pump turn on and water flowing at the tank. But it is not going overboard, instead into the bilge. Nut I cannot find a leak anywhere.
Blessed_C's
Vessel Info: 2000 530 Voyager with Cummins 6CTA8.3-M2
Postby Blessed_C's » February 20th, 2023, 4:40 pm
I have a Voyager 530 with a gray water tank under floor in master cabin. Where is the pump? I don't think it is working and seems to be draining into the bilge. Do you know specs for replacing?
thisDave
Vessel Info: 2003 Carver 570
Twin Volvo D12 650
Postby thisDave » March 21st, 2023, 10:44 pm
Blessed_C's wrote:Source of the post I have a Voyager 530 with a gray water tank under floor in master cabin. Where is the pump? I don't think it is working and seems to be draining into the bilge. Do you know specs for replacing?
In mine, the pump is actually inside the gray water tank. There's a float switch inside as well that triggers it. Soap and grime accumulates from time to time, we clean and vacuum it out at least once a year.
warren.corbin
Vessel Info: 1999 Voyager 450
Postby warren.corbin » April 28th, 2023, 8:33 pm
ColdCruisin, I’m new owner of 99 Voyager 450. In engine compartment last weekend changing filters and looking around. Noticed “Sump” breaker. It was off. I wondered what that switch controlled. Your post indicates it’s tied to gray water system. Can you explain?
Users browsing this forum: No registered users and 44 guests
