NEED PROPS
Used boat parts, used Carver boat parts, trailers, dinghies, outboards, props...everything but the boats they were attached to. ALL ADS ARE FREE - USERS MUST HAVE AT LEAST 10 POSTS TO PLACE AN AD
Forum rules
All classified ads for boat parts are free. Please be as specific as possible in describing your item. You can upload pictures too!
CarverYachtOwners.com and the owners of this forum take no responsibility for the authenticity of ads or legitimacy of items being sold. Buyers, please buy responsibly.
To place an ad start a new Topic. We reserve the right to delete ads from users with fewer than 10 posts.
jimpeter
Vessel Info: 2005 41 CMY
NEED PROPS
Postby jimpeter » July 7th, 2022, 5:13 pm
42 MARINER 2004. VOLVO GAS ENGINES LOOKING TO PURCHASE 2 PROPS. ANYONE KNOW WHERE I CAN??
C0ps
Vessel Info: 1992 carver montego 528
Has thanked: 3 times
Been thanked: 6 times
Re: NEED PROPS
Postby C0ps » July 7th, 2022, 5:46 pm
jimpeter wrote:Source of the post 42 MARINER 2004. VOLVO GAS ENGINES LOOKING TO PURCHASE 2 PROPS. ANYONE KNOW WHERE I CAN??
Check Face Book Market, Thats where I found Mine
Been thanked: 490 times
Re: NEED PROPS
Postby waybomb » July 7th, 2022, 6:48 pm
So far, 4 boats, and for each I bought spares on ebay.
Way cheaper than new from a marina, and all but the 3 cleavers, were all brand new.
I didn't need the props, I just wanted spares, so I had time. If you need them right now, you may need to shop supply houses for the best deal though.
I bought brand new spare Michigan wheels for the 3697, 600 bucks for the pair. You can get a good deal if you have the time.
jimpeter
Re: NEED PROPS
Postby jimpeter » July 8th, 2022, 9:38 am
ANYONE KNOW HOW I CAN FIND OUT THE EXACT INFORMATION ON THE TYPE OF PROP I HAVE? MANUAL STATES... HAWBOLDT INDUSTRIES PROP 24X24 DQBZ MG4 1-3/4
jimpeter
PROPS
Postby jimpeter » July 8th, 2022, 9:43 am
HOW CAN i READ THE DESCRIPTION ON MY PROPS. MAUAL STATES. TRYING TO BUY NES SET BUT VENDORS ARE ASKING FOR PITCH, CUPPING, ETC. CAN ANYONE HELP OUT....CARVER 42 MARINER.. HAWBOLDT INDUSTRIES PROP 24X24 DQBZ MG4 1-3/4
Re: NEED PROPS
Postby km1125 » July 8th, 2022, 10:03 am
That would be a 24" diameter 24" pitch with a 1-3/4 shaft. I would not expect it to be cupped out of the factory, but you never know what a previous owner might have done. You can usually double-check the shaft size by measuring where it comes into the boat.
If you don't have any spares (and I'm a FIRM believer that you should), then you if you could find a set CLOSE to those 24x24 specs for a good price, then I would pick them up and use them and eventually convert them to your spares when you find the permanent set. As long as the shaft size is the same, they will work but may not be optimal. Say, you might find a set of 24x22 or 23x23 or even a set of three blades vs the four that you presently have. It will get you back on the water. You can continue to search for an exact match for your permanent set, or you might run on those spares and find that you'd like to change from the OEM prop to something else for better performance on how YOU use the boat.
Re: PROPS
Postby waybomb » July 8th, 2022, 12:19 pm
24 x 24 is diameter x pitch
1 3/4" is shaft size
Been thanked: 285 times
Re: PROPS
Postby buster53 » July 8th, 2022, 2:05 pm
What’s wrong with the old ones? Unless they are mangled, there’s a decent chance a good prop shop can fix them. Took mine in for service as one had a blade a little out of pitch. Looked brand new when I picked them up and had a prop scan report to go with them.
Re: NEED PROPS
Postby buster53 » July 8th, 2022, 2:26 pm
Have you tried Google? Lots of prop shops out there and for something like you are looking for, I prefer buying local. You might want to let us know where you are located as we might know of a good shop near you.
Return to “Boat Parts For Sale”
Users browsing this forum: No registered users and 5 guests
