Checking in
4sailrguy
Vessel Info: 1996 Carver 325 Bonnie Berdine
Located at Hindman's Marina
Penetanguishene On.
Been thanked: 3 times
Checking in
Postby 4sailrguy » July 8th, 2022, 10:19 pm
Hi We are Annette and Eddie , boating out of Penetanguishene Ontario on our 96 Carver 325.... Bonnie Berdine.
email 4sailrguyeddy@gmail.com
Picking up very valuable information from other boaters here.
Good site
Re: Checking in
Postby km1125 » July 9th, 2022, 9:02 am
Welcome aboard!!
Re: Checking in
Postby Viper » July 9th, 2022, 10:37 am
Welcome aboard A&E
Re: Checking in
Postby RGrew176 » July 10th, 2022, 4:18 am
Welcome Aboard. You've come to the right place for anything Carver. Lots of great people here.
Been thanked: 490 times
Re: Checking in
Postby waybomb » July 10th, 2022, 4:28 pm
Welcome aboard!
4sailrguy
Penetanguishene On.
Re: Checking in
Postby 4sailrguy » July 10th, 2024, 11:09 pm
Thanks for the welcome one and all...very much appreciated.
Need some help.
'96 325
Crown head suddenly seized. Held the button too long to see if it would respond and the circuit quit.
Breaker labelled macerator has no wiring. OBviously wired to another breaker.
No power for new install. No fuse to be found. Everything else working.
Any solution other than a new wire run from the vacant breaker.
Thoughts appreciated
Eddie
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 210 times
Re: Checking in
Postby pepmyster » July 11th, 2024, 6:01 am
Welcome aboard! Someone will chime in for sure!!!!!!!!!!!!
Re: Checking in
Postby Viper » July 11th, 2024, 6:45 am
A "Macerator" breaker is usually for the overboard discharge not the head. Do you not have a separate "Head" or "Toilet" breaker? If not, look for an inline fuse. Hopefully someone with the same model will chime in.
4sailrguy
Penetanguishene On.
Re: Checking in
Postby 4sailrguy » July 11th, 2024, 10:48 am
Hi...Many thanks for the response
The "head" circuit, according to the Carver manual is the macerator breaker. Strangely, the breaker is vacant.
Obviously, the head was wired into another circuit. on checking the input switch, it is wired towards the ceiling. The red and black from the original discharge are wired thru the bilge.
Think I have located the hot going to the original head. couple of times has shown 12 on the meter...then another try, shows on 4-5. Last try came up negative. Should've checked closer when disengaging the original head I guess.
Best option njow is to wire into the "macerator" breaker and fish the line to the switch and new head.
Not impressed with Raritan's effort at the Era head. Cheap hose connection to toilet ,, no wiring diagram.
Confusing wire choicce diagram for newbies like myself.
Re: Checking in
Postby bud37 » July 11th, 2024, 11:03 am
If you still have the option available to return for exchange....get the Marine Elegance model. My advice would be to rewire all new, switches, breakers etc.
Users browsing this forum: Google Adsense [Bot] and 84 guests
