Replacement or repair of Stern Bench on 1988 Santego 30
theorifice
Vessel Info: 1987 Carver Santego 30
Has thanked: 16 times
Been thanked: 4 times
Postby theorifice » August 22nd, 2022, 11:21 am
Newbie move. Second time docking and swung stern wide and clipped neighboring boat's anchor on the stern bench. The port side bench mounting tore out (of the soft wood) and upholstery was torn
https://photos.app.goo.gl/RpjjEMAcY6U9NUr8A
Is it even reasonable to find a replacement bench for this vintage? Any suggestions for repair/replace? Are there specialty marine furniture shops? I am in Chicago.
I'm reasonably handy and based on the damage, I think I could do the following for the structure of the bench:
* remove as much rotted wood on the arm mounting points
* add wood hardener (epoxy) to the remaining exposed wood in the arm
* mount a suitable size piece of marine plywood to replace the fixed with through dowels and additional epoxy
* drill horizontal holes in the mounting points
* add prong nuts
* seal up the added plywood (more hardener??)
* re-staple upholstery
It's more important to me that the structure of the bench is solid. The damaged upholstery could be patched over for now.
Fun times on the 1988 Carver Santego 30
theorifice
Re: Replacement or repair of Stern Bench on 1988 Santego 30
Postby theorifice » August 29th, 2022, 1:56 pm
I did complete a repair that is roughly documented in this photo album: https://photos.app.goo.gl/RpjjEMAcY6U9NUr8A
Users browsing this forum: No registered users and 46 guests
