1994 GM 7.4 Edelbrock Carbs, Gen V
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
I am not a Champion person
- tonyiiiafl
Re: 1994 GM 7.4 Edelbrock Carbs, Gen V
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 138 times
2002 Carver 396
- tonyiiiafl
- Been thanked: 1113 times
A smaller gap would have been a bigger issue at light loads. At heavy loads you have a lot of fuel/air in the cylinder and higher pressures which makes it easier to ignite, so long as the spark can make the jump. Making the jump with a slightly smaller gap even makes it easier, which is very important at high loads and speed because the dense fuel/air charge can actually block the spark from jumping.
At lighter loads, you need more energy from the spark to ignite the gas, because it's not heated as much from compression. You also have less fuel and oxygen molecules floating around (and they have a bunch of nitrogen in between them) so having enough of them right between or close to the electrodes can be an issue and that gets worse as the gap gets smaller.
The smaller gap will still have a spark, but there's not enough fuel and oxygen molecules in that smaller gap to ignite, and you have a "miss". Won't happen ALL the time, but the percentage will increase exponentially with the smaller the gap gets.
Ideally you'd like a HUGE gap at low loads and low speeds and a TINY gap at high loads and high speeds. The manufacturer compromises to get the best of both worlds, and that's the spec you're shooting for.
- Has thanked: 602 times
- Been thanked: 1311 times
tonyiiiafl wrote:Source of the post plugs came out gapped at .030, spec is .035
Good job on the leg...Geeez....ouch.
Hmmmm...... Interesting as plug gaps generally widen over time, I wonder what they went in at...025-.028 maybe.
Anyway, one down one to go.....
Edit.......after thinking I checked the NGK gap spec for that plug and it is actually .031" according to their website.
- tonyiiiafl
And I am in the middle of recarpeting too.
- tonyiiiafl
