Where... water valve and light fuses...
- benica
- Vessel Info: 1997 355 Aft cabin. 7.4 engines.
- Has thanked: 1 time
- Been thanked: 9 times
Tried by myself and with shop and broker to no avail...
Need help...someone familiar with the 1997 355 aft cabin.
7.4 engines.
Just acquired this vessel yesterday...went for broke and don't want to regret it...
Filled the water take...50 or so gallons added. Water level guage near the sink shows...E.
We know the tank is full...
I am thinking...must be a shut off turn on switch...somewhere. No water at the faucets coming out. Generator panel...all switches...on.
Any idea where a water on off switch breaker is located?
If the boat has one.
Electrical...outlets work, plugged in fans....working...but no interior lights! Perhaps the water issue and interior lights....same breaker switch? Refrigerator works, microwave ok, outlets ok...just no interior lights.
Not finding a breaker box..
Appreciate the potential help from your experts!
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Where... water valve and light fuses...
I’m assuming your 355 is set up pretty much the same as my 356. The panel you mention next to the dinette is everything electrical, not just the genset. Left side is your 12 volt system and right side is your 120 volt system. All interior lights, water pump breaker and everything operated by battery are on the left side..12 volt.
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 137 times
2002 Carver 396
- buster53
benica wrote:Source of the post Apologies all....
7.4 engines.
Figure it out yet?
