Fuel usage
- Noelnjlyne
- Vessel Info: 2005 carver 33 SS
Fuel usage
(I realize that an "average" day is completely subjective and varies from family to family, but just trying to get a ballpark.)
Thank you in advance for any help!!
- Has thanked: 602 times
- Been thanked: 1311 times
Re: Fuel usage
Impossible to ballpark that, distance travelled, speed travelling to anchorage .....could run anywhere from 25 to multiple hundreds of dollars a day.
Play around with this calculator link, it will give you an idea of boat fuel usage.....
https://www.boat-fuel-economy.com/fuel- ... calculator
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Fuel usage
So, just going out a mile or two, anchoring and running your genset, you will spend $25. Go up from there.
Re: Fuel usage
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: Fuel usage
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
Re: Fuel usage
- buster53
Re: Fuel usage
Helmsman wrote:I had a Carver 33 SS 2006. After getting up on plane we would get .67 mile per gallon. Running at 11-12 miles per hour we would get about 2.1 miles per gallon. So those are two numbers to look at. I think you will find that running on plane actually distracts from enjoying the day, unless you are headed somewhere 20 or 30 miles away with little time to get there. I found we ran it faster when we first had it, but then Settled into a slower enjoyable ride, the longer we had the boat.
Hull speed for that boat is in the 7-8 mph range. At 11-12, you’re just pushing a lot of water in front of the boat. Hull speed is even more fuel efficient.
Re: Fuel usage
buster53 wrote:Source of the postHelmsman wrote:I had a Carver 33 SS 2006. After getting up on plane we would get .67 mile per gallon. Running at 11-12 miles per hour we would get about 2.1 miles per gallon. So those are two numbers to look at. I think you will find that running on plane actually distracts from enjoying the day, unless you are headed somewhere 20 or 30 miles away with little time to get there. I found we ran it faster when we first had it, but then Settled into a slower enjoyable ride, the longer we had the boat.
I think he meant 11-12 kph which is where I sit for hull speed. At 12mph the fuel consumption would be much higher.
- Helmsman
Re: Fuel usage
Buster, it has been a couple of years, so you are probably right. Thinking about it this morning after reading your comment, we would typically run around 9 or 10 mph most of the time, so that is the more likely speed for the stated lower fuel usage. At any rate, the fuel penalties for running hard can get quite dramatic.
Re: Fuel usage
