water leak
- jetstream
- Vessel Info: 2003 Carver MY 466
- Been thanked: 2 times
water leak
- Been thanked: 654 times
Re: water leak
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: water leak
Looking at the picture, that stream of water is definitely under pressure. Do you have any water fixtures in the vicinity… fresh water wash down, aft deck sink, etc. You just need to start opening any and all deck or bulkhead openings until you find the leak.
- buster53
Re: water leak
- ems05#05
- Vessel Info: 2004 466 my
twin volvo tamd75 - Location: mandeville la.
- Has thanked: 5 times
- Been thanked: 4 times
Re: water leak
Re: water leak
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 137 times
Re: water leak
Aft salon and master cabin a/c are off
What about the forward A/C or any other unit? Was it running? The reason I ask is that on our 396, there is only one A/C water pump that goes to a manifold that then splits out to the three individual A/C units (forward cabin, salon and aft cabin). If any one of them is on and the compressor kicks on (and hence the A/C water pump), water will be sent to all three units regardless if they are running or not. And you will also see water discharging from all three thru-hulls as well.
Keep us posted!
2002 Carver 396
- jetstream
Re: water leak
Nothing to do with each individual unit or the main pump, but somewhere in the system. Shutting off all the a/c and all water sources and waiting 15 minutes, it stopped. Restarted when the a/c was turned on. So I guess Carver designed it that way and no harm done, not causing any grief and we will press on. Just never noticed it before with the angle and light, etc. Thanks for all your posts.
