Shower leak 460 Carver
boatfamily4
Topic author - Scurvy Dog
- Vessel Info: 2005 Carver 460 Voyager
Thank you!
- waybomb
- CYO Moderator
- Been thanked: 490 times
Re: Shower leak 460 Carver
Carver should be able to tell you where to get the valve if it is leaking.
If one of the fittings is cracked, a plumbing house can help. They may even be able to help you with the valve.
If it is leaking at a fitting/vale joint, all you may have to do is remove the valve and tighten up the leaking fitting.
